Exhaust Question
Zed-dan
Exhaust Question
Post by Zed-dan » Mon 06 Apr, 2015 16:14
I have a stock exhaust on my 3.0 Z3, and I see no real reason to upgrade as the noise is lovely at high revs and quiet and domestic at low speed. However is there anyway to disable the valve that keeps it quiet? the valve that you can hear open between 2800 and 3300 RPM?
Any help would be much appreciated.
Not all those who wander are lost...
'00 3.0i /Custom painted Side Gills/Style 78's
beerbelly
Re: Exhaust Question
Post by beerbelly » Mon 06 Apr, 2015 16:24
pull the vacume pipe off and shove a golf tee in it the default position for the valve is open
kruisn
Post by kruisn » Mon 06 Apr, 2015 22:05
Is this an April fools joke or can somebody explain. I have owned my 3.0 litre since new and haven't a clue as to what exhaust noise is being discussed. What have I missed? Lol
Don't drink and drive home -
Take the Zd and fly home -
Post by spurs fan in a coupe » Mon 06 Apr, 2015 22:27
I've no idea what the answer is, but......... your car looks MINT!
Post by BladeRunner919 » Tue 07 Apr, 2015 08:27
kruisn wrote:Is this an April fools joke or can somebody explain. I have owned my 3.0 litre since new and haven't a clue as to what exhaust noise is being discussed. What have I missed? Lol
The 6 cylinder cars that still have a genuine exhaust have a small flap inside one of the two tailpipes (thought they have normally seized up anyway).
Post by Southernboy » Tue 07 Apr, 2015 09:47
The vacuum operated flap in the one pipe is designed to reduce noise in the "urban" driving environment and also to improve fuel consumption - according to BMW.
As stated above, one can disable the flap by pulling the rubber hose off and sealing it with a golf tee pushed into the hose.
Under normal operating that flap opens above a predetermined RPM to allow the higher volume of exhaust gasses to escape. By disabling the system one gets a louder and deeper exhaust note. TBH, I tried it and quite liked the note - for a while... but then re-connected it because the drone at low speed became intrusive.
For anyone wanting to do the disabling mod, the hose referred to is under the car at the back where the rear silencer box is located.
Zed-dan
Post by Zed-dan » Tue 07 Apr, 2015 20:54
Thank you all very much for your help southernboy :)
and I'm pretty sure the only reason its doing my head is that is nearly seized and as it changes from closed to open there's a detestable rattly raspy noise. and its right on the comfortable part of the mid range revs!
it doesn't look so mint atm... very very dirty...
Smartbear
Post by Smartbear » Tue 07 Apr, 2015 23:04
is this exhaust valve fitted to the 2.2 models?
regards
kruisn
Post by kruisn » Tue 07 Apr, 2015 23:36
Many Thanks Southern Boy. I would think my car valve has not rusted solid as it has only done 31250 ks. I am going to take up golf so I can buy a suitably high tech golf tee (in matching colour of course) and shove it up the tube. :lol: :lol:
Hoppo1979
Post by Hoppo1979 » Wed 08 Apr, 2015 12:52
I was wanting to do this mod on my Z3 3.0 but can't find it. Any pics would help.
Post by Southernboy » Wed 08 Apr, 2015 13:11
Here it is.......... Between the bak box and the bumper under the car.
Pull the hose off and plug it with the golf tee.......any colour will do unless like some you're anal.... :lol:
Don't you just love the lack of rust we enjoy here..... :twisted: :lol: :lol:
bazza1966
Post by bazza1966 » Wed 08 Apr, 2015 18:05
Guys info please is this also on pre face lift 2.8? thank you in advance. :rtm:
Bazza (East Dorset)
Post by Southernboy » Wed 08 Apr, 2015 19:05
Hi Bazza..... short answer - No.
johnz3
Post by johnz3 » Wed 08 Apr, 2015 20:34
In the picture there is a frayed hose which gets capped off by the golf tee. Understand that. I cannot however see how the hose connects to the 'cap'. I was expecting a male/female type arrangement. I would like to try this but worried how it all goes back together. Not clear from picture. Thanks
Post by Southernboy » Wed 08 Apr, 2015 20:41
The hose slips over a small steel tube coming out of that valve... simply give it a tug - it'll slip off... as you see the hose doesn't even have a clamp on it....:wink:
johnz3
Post by johnz3 » Wed 08 Apr, 2015 20:50
I know I am labouring the point but where is the small steel tube then.
beerbelly
Post by beerbelly » Wed 08 Apr, 2015 21:46
in the pic its inside the end of the braided hose where it joins on to the metal diaphragm housing just pull it off can southernboy circle it for him :wink:
Post by Southernboy » Wed 08 Apr, 2015 22:07
The tube is still connected to the pipe in the pic I posted.... as I said, I had tried it disconnected and plugged, but I found the noise too much at low speed and re-connected it again... hope that clears up any confusion... :wink:
johnz3
Post by johnz3 » Thu 09 Apr, 2015 06:07
Ok and thanks
bazza1966
Post by bazza1966 » Thu 09 Apr, 2015 19:03
Southernboy wrote:Hi Bazza..... short answer - No.
THANKS for reply shame thou :(
Bazza (East Dorset)
Post by Southernboy » Thu 09 Apr, 2015 19:42
........ My apology Bazza.... no rudeness intended. :oops:
Zed-dan
Post by Zed-dan » Fri 10 Apr, 2015 17:52
Did it this afternoon and I am chuffed! A slightly deeper note and a nicer noise up to 3500 as now it doesn't have a rasping valve!
Are the tail pipes removable for a good clean on the stick exhaust?
Many thanks :)
johnz3
Post by johnz3 » Fri 10 Apr, 2015 18:44
PM sent re your post Zed-dan
Zed-dan
Post by Zed-dan » Fri 17 Apr, 2015 16:17
As shown above, gently pull back the braid and remove and plug the vacuum pipe. Then tidy away :D
(I ziptied mine up so it doesnt fall...)
johnz3
Post by johnz3 » Fri 17 Apr, 2015 16:36
Thanks for that. Had a quik feel under last weekend and could feel what is shown in the picture. Will have a proper look tomorrow. Would you know if all 3.0i Zs should have what is shown in the picture. Thanks.
Zed-dan
Post by Zed-dan » Fri 17 Apr, 2015 16:37
Its on all STOCK 3.0i exhausts.
johnz3
Post by johnz3 » Fri 17 Apr, 2015 17:23
Ok. Thanks.
beerbelly
Post by beerbelly » Fri 17 Apr, 2015 19:11
think its on the 2.8 too but as ours has a stainless system I cant check. my 2.5 z4 has it too
Brian4
Post by Brian4 » Fri 17 Apr, 2015 19:37
I have read somewhere that the flap was not fitted to the autos but I may be wrong. Ours hasn't got the valve but the vacuum solenoid is fitted in the well behind the rear wheel.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
johnz3
Post by johnz3 » Fri 17 Apr, 2015 19:57
In Zed-dan's picture is that the vacuum solenoid as opposed to the valve?
Brian4
Post by Brian4 » Fri 17 Apr, 2015 20:18
johnz3 wrote:In Zed-dan's picture is that the vacuum solenoid as opposed to the valve?
No John that is the valve. the solenoid has electric wire and the small pipe to and from it. I think it was under the tilt alarm sensor l hand side boot in the well behind the rear wheel.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
johnz3
Post by johnz3 » Fri 17 Apr, 2015 20:26
Thanks. Learning all the time ......
Post by peter2b » Fri 17 Apr, 2015 21:42
had a play in my 2.2 on the way back from its MOTin 3rd @ 2K rpm not a lot but upping it to 3-4k the exhaust note changed a lot deeper
mwpe
Post by mwpe » Fri 17 Apr, 2015 22:07
Brian4 wrote:I have read somewhere that the flap was not fitted to the autos but I may be wrong. Ours hasn't got the valve but the vacuum solenoid is fitted in the well behind the rear wheel.
I think this must be true as my 3.0 litre auto definitely does not have the valve or pipe.
Users browsing this forum: No registered users and 12 guests
