gear knob lights
gear knob lights
do all z3s have a light In the gear knob? mine is a m type 5 speed but has some big scratches on the top and no light so I want to change it seen one on flee bay that has a led in it that looks nice
Re: gear knob lights
No they don't all have lights, the wiring should be there if you wish to connect one though.
thanks , I will have a look this weekend
Just the thing for Americans, who do not know where the next gear is . . . .
Only the Z3M one lights up. The M gearknob in the non-M Z3s, part of the Mtech pack, doesn't light up.
The one in my 2003 3.0i sport lights up.
The one in my 2.2 lights up, part of the Msport setup i suppose.
Albert
Albert
Does that mean Non-m Z's got the wiring? Forgot to check when i changed the gaiter.Brian H wrote:No they don't all have lights, the wiring should be there if you wish to connect one though.
Yes it does, be careful when connecting it up, if you short the connection it blows the rheostat in the light switch.thompy93 wrote:Does that mean Non-m Z's got the wiring? Forgot to check when i changed the gaiter.Brian H wrote:No they don't all have lights, the wiring should be there if you wish to connect one though.
just had a look under the gear stick cover the only wires there are for the windows no spare connections for the knob light ( no sniggers) any way the new one looks much better then the old one, I think some one tried to prise the top out leaving it with crazing in the plastic
There are lots of spare wires under there, including for a telephone kit, OBC, heated seats, etc. The loom is behind the heater controls and any spare connectors may well be folder back and taped to the loom itself, rather than floating about near the gear lever.
Cheers only looked towards the back not the front I will have another look tonight
Peter2b
Peter2b
