Asc switch
lacedr
Asc switch
Post by lacedr »
Does anybody know what switch should be fitted to my 97 1.9 and what colour wires it should have going to the connector block.
the reason for asking is my car has a switch fitted but not connected so am not sure if i have the correct one or not.
cheers
kjb1
Re: Asc switch
Post by kjb1 »
my 97' 1.9 didnt have ASC. You had a dash which has asc button but car doesn't maybe?
Sent from my iPhone
Re: Asc switch
Post by colb »
Just had a look on OEM site and parts listing for a 09/98 model shows the switch as an option if stability control is fitted to the car as an option so maybe yours didn't get built with that option and someone has added the switch in the blank space it would have had?
http://www.realoem.com/bmw/enUS/showpar ... Id=61_1089
Might be worth looking to see how it left the factory by looking up your car on
http://bimmer.work/
to see the build options for your car based on its VIN number using the last 7 numbers.
Mine has ASC switch and is connected and works however on the build options its not listed, mine is a 1999 model
2003 BMW 2.5 Z4
Re: Asc switch
Post by bertiejaffa »
I thought all Z3s had ASC (DSC on later models) apart from the M
lacedr
Re: Asc switch
Post by lacedr »
thanks for the replies cant see it on the build sheet but i do have the twin throttle bodies and it looks like it is all connected, i shall ivestigate a little further.
cheers
Re: Asc switch
If the sticker on the ABS control until (attached to the pump) is still visible, then it should say ASC if you have ASC.
lacedr
Re: Asc switch
Post by lacedr »
Thanks I will check in the morning
