DSC and reduced power
Hi guys, I can't get my car into my local garage until Monday so I'm looking for some advice here. I've just completed the NC500 in my z3 3.0, fantastic by the way, get in done! Anyway, I was taking a long corner downhill in the wet around 80mph when I hit a little pot hole, it wasn't a teeth grinding moment it was just a little one. My DSC light flickered then stayed on and my rev counter bounced to 0 then back up. I pulled over and the car sounded a little rougher. Left it half an hour because I thought maybe I had been pushing it too hard. Started it up and it took 5 or so seconds to start. At first I thought it was a fuel problem as I was driving away it felt like I was towing a caravan or the fuel was being restricted. After nursing it home it felt more like the DSC had kicked in permanently, I could still get up to speed but it took a while. Please don't tell me it's my DSC unit. Any advice or knowledge welcome
Re: DSC and reduced power
You'll need to pull the codes to get any idea of what's wrong. We'll be guessing otherwise.
The M54B30 engine uses the main throttle as the throttle control for the DSC, so the DSC overrides your right foot.
The Idle control valve is used as the main throttle up until about 30 MPH (50 kmph) then the main throttle comes in.
My guess view is that it is too much of a coincidence that this happened immediately after a spirited drive in the wet and hitting a pot hole. I suspect the traction control was triggered and the ECU “forced” the throttle to “rein in” its operation and thus cut the car’s power. If it’s not clearing itself after a few stop/start driving cycles I would suspect damage to a wheel or tyre (or tracking) that is still fooling the ECU into believing that one or more wheels are not rotating together at the same speed.
What is the status of your DSC lights now? Are they on or off? Did you notice one or both of your rear wheels getting warm/hot?
I checked all wheels after it and there was no heat. The DSC light has been on since and hasn't turned off. Car is very sluggish to start also. I know I won't know until I get it on the computer but I was hoping someone had faced similar problems. I have driven the car since hoping it would clear but to no avail
With the DSC light on it could be something as simple as a sensor, the car thinks it is permanently in a state of flux and that is why it is sluggish, give me a shout if you want me to hook up my PC to see if we can see anything.
That is what I am hoping Brian, that I have maybe just upset a sensor rather than something a lot more expensive. That would be grand if you had any free days anytime soon
I am around this weekend, drop me a PM and we can see if we can sort something out.
Thanks for the offer Brian, managed to get it into an auto electrician today around the corner from me. His computer said it was the crank shaft sensor but surely the engine management light should have been on? He said he was surprised the car was still going. He managed to clear the code and the car went back to normal. I want to know why it happened and why it was so easy to sort without replacing the sensor. He told me to keep and eye on it and if it happens again he'll replace it.
Clearing the code will not have fixed the problem. If the car went into limp mode, then it may allow it to return to normal for a while. These sensors tend to go intermittent rather than failing outright, so I suspect the problem will return. I had a camshaft sensor go on mine and it wouldn't run for more than about 10 seconds. AA man came out, fiddled with the HT leads and it went back to normal. Got diagnosed next day and it reported camshaft sensor, so it was replaced and has been fine since, as I had no desire to repeat breaking down on a busy dual-carriageway.
Thank you for the feedback Robert I appreciate it. I love quite rural so no dual carriageways thankfully but I fully expect it to come back on. I'll give it a month to come back on, if not I'll replace it anyway. Cheers
