Loss of power
stupot50
Loss of power
Post by stupot50 »
My 2.8 seems under powered at low revs when cold, struggles to pick up speed in high gears. When the engine is hot it turns over 6 times when trying to restart it and then is very underpowered in all gears. Any ideas gents?
1999 2.8 Arctic Silver Z3
2007 325d Msport - remapped
Re: Loss of power
Post by colb »
Put a code reader on it to see if it has set any codes that may guide you to what is wrong. Codes set may actually be caused by something else in the system so be aware that something in the system may be not working correctly and upsetting something else hence the codes you may see. A bad Maf is a possible cause it dosn't always set a code pointing itself out but causes codes such as exhaust sensors to be set as the ecu isn't getting the right info from the Maf. A Bad Maf may not set an engine management light and you could end up replacing sensors that are still ok. If you disconnect the Maf connection see how the car responds as it will revert to a default setting. If it runs and starts ok with Maf disconnected you will probably found the cause. Do not but cheap pattern Maf's go for either Bosh or Seimens OEM. The cheap ones are of doubtful quality and rarely last long if they work at all.
Whilst your under the bonnet check all rubber hoses for air leaks, any cracked hoses should be replaced, these engines are very particular with the induction side of the engine being airtight. Leaks will cause all sorts of running problems and codes being set.
2003 BMW 2.5 Z4
Re: Loss of power
Post by gookah »
I have been suffering from a similar problem on my 2.8. Down on power and then recently started misfiring. No codes at all being set.
I disconnected the plug to the MAF and it restored everything. One second-hand MAF later and all is good again
this test costs nothing and takes 30 seconds. Try it first.
Howard Adams
Re: Loss of power
Post by Howard Adams »
Hi, sounds like a possible MAF, historically they don’t always generate a fault code. As mentioned in this post it’s always best to use a reputable brand..
Good luck.
NZ00Z3
Re: Loss of power
Post by NZ00Z3 »
Sounds like an inlet cam sensor fault. You will need to read the fault codes in the DME to know for sure.
Howard Adams
Re: Loss of power
Hi, interestingly enough when my Z3 (3.0i) had intermittent loss of power it showed immediately on the code reader.
Camshaft sensors do seem to be a common problem with many Z3 (6cyl)
stupot50
Re: Loss of power
Post by stupot50 »
Had a scanner on it. Only code was cam sensor, replaced it and it's no different :cry:
Re: Loss of power
Post by mrscalex »
stupot50 wrote: Sat 21 Apr, 2018 07:49 Had a scanner on it. Only code was cam sensor, replaced it and it's no different :cry:
BMW part or 3rd party? Some 3rd party sensors are cr*p. Recommendation for critical stuff like this is BMW. Not cheap unfortunately.
stupot50
Re: Loss of power
Post by stupot50 »
Not sure of manufacturer as it was supplied and fitted by an indie, trying to find out now
Re: Loss of power
Post by colb »
Have you disconnected the Maf electrical plug and tried the car as with it unplugged it should run on default settings. If it runs better then that would point to the Maf being bad. You could try cleaning it with Maf cleaning spray but cleaning rarely fixes a bad maf in my experience. As a replacement Maf is expensive is there anyone close to you with the same engine as yours who would be willing to try their working one in your car?
If you go down the replacement route make sure you buy a oem part Siemens or Bosch same for all sensors, cheap pattern parts are false economy, been there done that lessons learnt.
2003 BMW 2.5 Z4
Re: Loss of power
Post by mrscalex »
I'd rather have a secondhand OEM than new cheapo make.
I bought one recently for £20 and it's doing a good job.
stupot50
Re: Loss of power
Post by stupot50 »
Yes I have disconnected the maf, made no difference. Looks like my indie used a cheap sensor. I don't suppose anyone out there has a good one that they are willing to part with is there?
Robin82
Re: Loss of power
Post by Robin82 »
Had the same issue years ago, used a euro car parts Cam sensor and had no effect so ended up sending it back and buying OEM for £108. It improved but I still felt the power wasnt there. When my head gasket blew replaced the Crankshaft sensor and hey presto. Weird. A mechanic I spoke to said the two sensors can effect one another.
