Abs / traction light
Hdz3
Post by Hdz3 » Sun 08 Oct, 2017 15:46
Hi, just had two New front tyres on my z3 , and a day or two later the abs/traction light has come on , before it came on the abs started working when braking at low speed , check tyres both the same size.circuit board was repaired two years ago .
Re: Abs / traction light
Post by peter2b » Sun 08 Oct, 2017 20:22
I had new front tyres fitted a couple of months ago but only get the abs light to come(red light with a triangle in it) on when I pull away on muddy or wet roads
peterz3
wifevanda
Post by wifevanda » Mon 09 Oct, 2017 21:21
Hi changed my absence module a year ago .Been OK now playing up again .anyone got a link to just get the module overhauled .
wifevanda
Post by wifevanda » Mon 09 Oct, 2017 21:24
Hi changed my abs module a year ago .Been OK now playing up again .anyone got a link to just get the module overhauled .
Hdz3
Post by Hdz3 » Wed 11 Oct, 2017 19:05
Checked tyre pressures, a little high dropped them to 29 , lights still on.
Post by Robert T » Wed 11 Oct, 2017 20:17
Get the codes read and find out whether it is a wheel sensor or the pump/control board. Having the wheels off may have disturbed some dirt, or the wiring, but unless you read the codes, you won't know which wheel to check.
alec.m
Post by alec.m » Thu 12 Oct, 2017 17:14
Check the wire to the wheel sensor. I had new brake pads fitted a couple of years ago and somehow the wire came loose, rubbed on something and the insulation wore away and it periodically earthed itself and that lit up the ABS light.
