ZZZEMMCO
Post
by ZZZEMMCO » Thu 10 May, 2007 15:35
Has anyone heard of problems with Falken Tyres UK contacts.Site shows down for an update, and saw a post that said they had tried to get through but telephone had probs
safetyfast
muppet
Post
by muppet » Mon 28 May, 2007 11:08
I bought mine from a local tyre place who supplied and fitted/balanced for the same price as Falken were charging to post them to me . another avenue
I have been diagnosed with ADHOTS. Attention Deficit Hyperactive Ohh That's Shiney
AndyBass
Post
by AndyBass » Mon 28 May, 2007 12:58
Which Falkens did you go for Mupps? I'm considering FK452's when I need new tyres to replace the Bridgestones.
We all have a photographic memory, just some don't take the lens cap off!
muppet
Post
by muppet » Mon 28 May, 2007 13:05
AndyBass wrote: Which Falkens did you go for Mupps? I'm considering FK452's when I need new tyres to replace the Bridgestones.
the fk452's they seem to work
johnz3
Post
by johnz3 » Thu 21 Aug, 2008 10:45
AndyBass and Muppet
Are you still happy with your Falken FK-452.
I need four new tyres and these seem best.
Adam
Post
by Adam » Thu 21 Aug, 2008 11:26
I recently put falken fk-452's all around on my Z.
Got mine from Black circle tyres online and used a discount code from here :
www.vouchercodes.com and got a % off.
Cant fault them so far, road noise good, handling & wet weather is very balanced and good alround. I fully expect there to be better options but at what cost. if your budget wont allow higher rated tyres then go for the falkens.
Next time I will probably go for the toyo proxies as I had them on my old volvo and they were cracking tyres. Just to see what they are like on the Z.
johnz3
Post
by johnz3 » Thu 21 Aug, 2008 11:57
Thanks Adam.
I have the toyos on at the monmnet but am told you can no longer get them?
I will check again
big cheesy
Post
by big cheesy » Thu 21 Aug, 2008 12:02
I have had fk 452's all round for last year and a half, Definately recommend them. I used the Falcon web site and found local garage to fit no probs. Good tyre at a decent price.
ChrisXL
Post
by ChrisXL » Thu 21 Aug, 2008 12:27
Try
http://www.mytyres.co.uk/
I have the FK 452 235/40/18 and 295/30/18 on the M.
Third set and still reall happy with them.
SpunkyM
Post
by SpunkyM » Thu 21 Aug, 2008 15:48
FK452's are brilliant tyres for the money. In fact even if they cost £120 per corner they'd still be brilliant. I've been recommending them for ages.
RonZ
Post
by RonZ » Thu 21 Aug, 2008 20:15
Very happy with mine £340 fitted from Protyre.
RonZ
muppet
Post
by muppet » Fri 22 Aug, 2008 23:07
just bought 4 more
AntMan
Post
by AntMan » Sat 23 Aug, 2008 06:38
johnz3
Post
by johnz3 » Sat 23 Aug, 2008 18:32
Just had four 452 tyres put on but forgot to ask the fitter what the pressures should be.
Any ideas please. If it matters it is a 1997 2.8.
Dav
Post
by Dav » Sat 23 Aug, 2008 19:42
I run mine at 32 all round.
Dav the wheel nut
muppet
Post
by muppet » Sat 23 Aug, 2008 19:46
johnz3 wrote: Just had four 452 tyres put on but forgot to ask the fitter what the pressures should be.
I have '99 facelift 2.8 and it is 29 at the front and 32 at the rear
