brake upgrade m43
pacey
brake upgrade m43
Post by pacey »
I want upgrade my front brakes..
what i need if i want upgrade on e46 330i brakes?
Re: brake upgrade m43
Post by BladeRunner919 »
What are you trying to achieve with the upgrade?
pacey
Post by pacey »
BladeRunner919 wrote:What are you trying to achieve with the upgrade?
i have a lot plans...one is m engine 8-) because i want big brakes :D
i have a lot parts from stronger model(rear axle, drive shaft), coilovers..
next are brakes, than engine 8-)
Zedonist wrote:The 1.9 discs are smaller diameter and are not vented, so I guess a swap to e46 or z3 2.8 / 3.0 will give a larger rotor and vents that will improve braking, I am doing this in the new year, just got to source the calipers and discs for renovation, and fiment should be a straight swap and bleed of he system. A couple of members have already done this.
yes i know for that...
but in realoem z3 1.9(m43 118hp)
have differently front calipers(only :evil: ),
because i think go on front 330i brakes 8-)
Post by gookah »
This is what I did, see towards the bottom of the thread....
http://www.zroadster.net/forum/viewtopi ... 32&t=34086
Used 6 cylinder brakes (2.0/2.2/2.8) Had to change the carriers, discs and callipers.
Post by gookah »
Zedonist wrote:Spot on Gookah, thanks for posting, will help for me anyway,question, how do you find your HU?
No problem, glad it is of use.
Re the head unit, It is a nice unit, and nice sound, but there are a few niggles, one is the lack of info on the screen,
you get about 8 characters on two lines to determine the track name, artist etc, and it isn't really enough, and scrolling takes ages - trying to read and drive? not the best.
Also slow to scroll through song titles, they start playing before the description comes up.
Oh and the sub pre-outs tend to make a droning noise on my sub, I had to use the high pass connection for my sub to get around this.
I have two of these units at present and they both show the same niggles.
pacey
Post by pacey »
thank you all guys...
i found in Croatia from e46 328, same as z3 3.0
brake disc(2000km pass) 300mm, brake caliper + carrier(both) for 55euro :D
for 2 days i will go for them
pacey
Post by pacey »
Zedonist wrote:Wow that is a good price, was that ebay?
no,
i was ask on croatian forum for buying set, and thats offer :)
Post by g8jka »
I have upgraded to 300mm brakes on the front, from the standard 286mm found on the 6 cylinder models (see my journal).
I only had to change the carriers and discs, as the calipers are the same across the 6 cylinder models so they were already there on mine and pads are the same on both 4 and 6 cylinder models meaning you could use your current pads. Probably be worth changing the fluid whilst your doing the swap but it is fairly simple and a relatively cheap upgrade and definitely worth while.
COCO
Post by COCO »
g8jka wrote: Tue 27 Nov, 2012 11:02 I have upgraded to 300mm brakes on the front, from the standard 286mm found on the 6 cylinder models (see my journal).
Hi, I want to do the 300mm upgrade as well is it worth it?
How do you find it raported to stock brakes? What carriers did u use?
Thank you
I’ve lots of vented 6 cylinder 286mm brake upgrade kits (callipers and carriers) .
Pm for details
