On my 2006 E85 roadster the pax side window squeaks loudly on up and down movement, I assume it's the rubber guide seal that sits on the top for the door. I've tried silicone, other stuff including WD40, but no success. It did run quietly for a time a while back but don't know why.
I assume that the rubber has hardened. I can't find a replacement rubber online, tried the BMW parts list as well.
Any solutions out there please?
Squeaking side window
- beemingallover
2006 Z4M roadster. Interlagos Blue/Sepang.
2009 M3 coupe (E92) manual. Silverstone Blue/Black.
1986 M635Csi manual. Lachs Silver/Black.
Re: Squeaking side window
Perhaps thorw a brick at it ?
- beemingallover
Tried that, but the brick bounced back! German engineering, British brick!!
Gummi plfledge (spelling?) Use in on all my window seals, Z3, Z4M coupe and now M240i Conv.
2001 Z3 3 litre Sport Roadster - titanium and special
2006 Z4M coupe - Interlagos and red
http://i1167.photobucket.com/albums/q62 ... huiwqu.jpg
- beemingallover
Solved it, the problem, the squeaking, was coming from the window motor regulator. Replaced it last year, operates smoothly and quietly since.
- beemingallover
Z3andZ4, thanks.
I use a lot of it as it’s great when hard top goes off and off seasonally and it’s the only thing that works to stop those nasty chassis twists when the hard top is not set right. Good luck.
