Manifold heat shields Z1
TJS
  Z1 roadster
Post by TJS » Tue 10 Apr, 2018 21:00
Has anyone replaced the combined exhaust manifold gaskets and heat shields on a DIY basis ?
They are not leaking however, the rear heat shield element is holed. The original metal weave laminate style has been replaced with what looks like thick grey cardboard. See below
Pondering the job this afternoon it seems the plastic header tank and ignition rail comes off and plugs out, under tray off and loosen the manifold / exhaust clamp before attempting to undo the 12 brass manifold nuts. Space is extremely tight and a snapped stud would be a disaster, probably resulting in removal of the cylinder head to rectify. No way could you drill it out and re-tap the thread with the head in situ.
Alternatively.
1. The car is due an Inspection 1 service and a 5 year / 7k mile cam belt so do I ask the BMW dealer to fit them at the same time ? Although if they break a stud and the head comes off I assume I will pay for it.
or
2. Just live with a holed heat shield and the associated OCD.
felix
  Z1 roadster
Re: Manifold heat shields
Post by felix » Wed 11 Apr, 2018 20:42
Given your garage how could possibly be even thinking there is more than one answer?! :)
a1z1
  Z1 roadster
Post by a1z1 » Wed 11 Apr, 2018 22:11
Hi Bluebaur has a solution that looks good and doesn't require removal of the manifold.
I changed the manifold gaskets on a z1 last year, Shall we say it was character building. :head:
There is a tool that allows the drilling and re-tapping of the cylinder in situ .. but you do need a 90 degree head drill.
The pictured broken stud is at the rear of the engine near the bulkhead.
ImageThe nuts and studs are available as a set.
Good luck!!
________________
urzzz
  Z1 roadster
Post by urzzz » Thu 12 Apr, 2018 20:08
I don't know anything about nuts or studs, but I wonder if your coolant is a bit low? I understood that the arrows marked the 'minimum'. No doubt would be picked up at Inspection 1 anyway, but maybe one to keep an eye on. Toby
"There are roadsters, then there is the Z1", Brett Fraser, Car Magazine Aug 1989
"The BMW is simply superb", LJK Setright, Car Magazine, Apr 1990
"It's impossible to drive without a smile", Rowan Horncastle, TopGear.com Sep 2017
sfh3l
  Z1 roadster
Post by sfh3l » Tue 17 Apr, 2018 11:28
My coolant always goes down when cold and up to the line when warm :-)
The studs do have a tendency to break, as well as unwinding themselves occasionally. I have not long ago done all of this on my 318is, where the manifold was cracked and needed welding. I got it off and removed all the studs to replace as a precaution. All came out like good boys and girls, so I was lucky.
Personally, I would suppress the OCD and live with it. It could be a bitch of a job (simple enough if all goes well) and my thoughts would be that sooner or later you'll need to do something that necessitates a head-off or engine-out job, at which point it comes into play as another little job to add to the list of things you'd do if you had to.
M20's tend to blow head gaskets and crack heads. One of us will, sooner or later experience this and that is a perfect opportunity to attend to nasties like this one. Till the, for me at least it is another of those dogs that continue to sleep soundly :roll:
Best regards,
Sam Lever.
My Financial Blog
Jet
Post by Jet » Wed 18 Apr, 2018 08:11
They are not leaking however, the rear heat shield element is holed. The original metal weave laminate style has been replaced with what looks like thick grey cardboard. Just live with a holed heat shield and the associated OCD.
OCD is usually triggered by the 'visible', so as the gasket isn't the issue, and its the heatshield that bugs you out, cut away the shield leaving the gaskets in situ. Cut a new gasket leaving the shield, combine the 2 with an invisible join, no more OCD.
After 28 years and 30k miles, I wouldn't attempt to remove those nuts unless necessary.
sfh3l
  Z1 roadster
Post by sfh3l » Wed 18 Apr, 2018 08:42
[/quote]
[/quote]
Couldn't put it better myself. Get therapy for the OCD TJS and don't worry about your nuts :D
Best regards,
Sam Lever.
My Financial Blog
TJS
  Z1 roadster
Post by TJS » Mon 23 Apr, 2018 11:34
Thanks to all for the advice and input. Hmmm...
I used the car yesterday for the first time in 18 months (good to see you Sam) and it runs perfectly. It's the rear heat shield which is holed, it just bugs me.
Patching with the heat shield element of the new gasket is an option but there is not a lot of the old shield to rivet to. Having recently rectified a broken rear manifold stud on another straight 6 (Land Rover) I know what Ivor means about "character building". Luckily a nut could be tacked onto the remains of the stud and it came out. As usual the job evolved into a longer list of tasks on the "may as well why were are here" principal to include de-coke, head skim, new head gasket, water pump rebuild, manifold gasket, new exhaust values and stem seals. Something I would prefer avoid on the Z1.
On balance I don't think I am going to risk a problem on replacement but will fit a couple of thermal sleeves over the two plugs leads above the hole. They worked well on the TVR which had almost nuclear levels of engine bay heat. This will also give me time to attend CDO therapy, (the acronym letters need to be in alphabetical order) and attend to my other nuts.
Jet
Post by Jet » Mon 23 Apr, 2018 14:24
:D :D
sfh3l
  Z1 roadster
Post by sfh3l » Mon 23 Apr, 2018 16:59
Good to see you too TJS. I'm glad the nuts are OK and I agree re the shields. In any case, I reckon you'd need a licenced asbestos removal contractor in to do it for you.....
Got as far as Chuny-sur-Semois, Belgium in one piece in the 911. Oh ye of little faith !:-)!
Best regards,
Sam Lever.
My Financial Blog
TJS
  Z1 roadster
Post by TJS » Wed 26 Jun, 2019 09:53
With the new heat shields sitting on the bench goading me to fit them and break a manifold stud, or two, I finally put them away and bottled out by fitting heat sleeves over the two plug leads above the holed heat shield.
bluejay
  Z1 roadster
Post by bluejay » Fri 28 Jun, 2019 07:21
My heatshields have long gone.... thinking about installing a new header, then they would be replaced anyway...
my OCD is killing me on this, thanks for reminding me...
Robert
