Tyre Pressure labels.
TJS
  Z1 roadster
Post by TJS » Mon 16 Jul, 2018 17:26
Are all Z1 tyre pressure labels underneath the fuel filler cap?
Replacements are no longer available from BMW, however, I have arranged new ones from Pukar Designs. The initial version is too large and follows the standard BMW sized label which is usually found in the door aperture. It is currently being scaled down to the correct 750 mm x 30 mm size as per attached photograph and amended to delete the 225/45 R15 MS information line. Ideal for those who have replaced broken filler flaps or the label has bubbled due to fuel fumes like mine.
If not under the filler cap where would the type pressure label be located on a Z1?
The green "Bleifrei Tanken" fuel labels are also available, see website.
http://www.pukardesigns.com
Jet
Re: Tyre Pressure labels.
Post by Jet » Tue 24 Jul, 2018 09:27
website down, but thanks TJS, I will order some of them. Unable to help with your question, as not aware of any other position for the label.
TJS
  Z1 roadster
Post by TJS » Mon 30 Jul, 2018 13:45
Re-sized and amended "Mk 11" version.
Job done. On to the next task, fit the new "arrow head" captive plates to the headlight pod bolts.
TJS
  Z1 roadster
Post by TJS » Wed 26 Jun, 2019 10:09
Having woke the car up from its winter hibernation and a new MOT you notice small jobs for the "to do list" like replacing the original but delaminated "parts warning" label. However, no more jobs on the list and therefore no excuse not to get out and enjoy the car in the forecast sunshine.
Users browsing this forum: bluejay and 4 guests
