Blinkers won’t go off
JohnW3
  Z1 roadster
Post by JohnW3 » Sun 02 Jun, 2019 22:27
Both blinkers on my car have turned on and they won’t go off. I have had to take the fuse off.
Has anyone run into something like this? Anyone have any idea of what the problem might be?
Thanks,
JW
TJS
  Z1 roadster
Re: Blinkers won’t go off
Post by TJS » Mon 03 Jun, 2019 13:28
A sticky hazard warning light switch maybe ? The rear fog light switch has been known to stick in the on position, probably due to lack of use.
Jet
Post by Jet » Tue 04 Jun, 2019 09:32
Failing that, the circuit runs through the same relay switch (I think), just separate fuses (No4 and No24), check all fuses and the relay.
felix
  Z1 roadster
Post by felix » Wed 05 Jun, 2019 16:33
Or an alarm system that's been triggered?
Stoertie
  Z1 roadster
Post by Stoertie » Sun 16 Jun, 2019 12:22
Hi John,
the triggering of the blinkers is very simple. The warning light switch pulls one port of the bilnker relay to ground therefore the brown/blue cable is used.
The switch at the steering wheel gives +12V to the relay for blinking right or left.
If the car is blinking to both sides I think it's a short to ground between the brown/blue cable from warning light switch to relay or the blink relay itself is the problem. You can test it by disconnecting the switch. When blinking stops it's the switch, if not it's a short beteen cable and ground or the relay.
Here is the scematic diagramm of the blinker section:
(62.63 KiB) Not downloaded yet
Michael
