Z1 - Oil cooler access
Jet
Post by Jet » Thu 26 Dec, 2019 23:23
Gents,
Need your help. Been putting this off for ages, but has anyone ever replaced the Oil cooler? The top plate came loose, but not noticed any sort of adverse effect, drives the same, temperature the same, do I even need it?
They seem to be unique to this car, not shared with the e30, are they easy to replace, just undertray and front bumper off?
Jet
TJS
  Z1 roadster
Re: Z1 - Oil cooler access
Post by TJS » Mon 30 Dec, 2019 13:14
J
I assume the "top plate" is structural to prevent twisting and leaking. I would have a chat with Aaron Radiators in Crystal Palace about a repair, they should be able to braze the cover back into place. I have used them in the past for MG and Land Rover radiator re-cores.
https://www.aaronradiator.co.uk/classic ... l-coolers/
Good luck getting it out of the car.
sfh3l
  Z1 roadster
Post by sfh3l » Sun 05 Jan, 2020 15:52
Hi Jamal,
I replaced the oil cooler pipes on my E36 M3 a while back and, apart from the connections to the cooler itself being pretty crusty, it was easy enough to get it out and freed. You wouldn't need the bumper off, just the undertray. I would replace pipes and cooler together for peace of mind on a car of this age, togther with the 'o' rings that come at each end of the pipes. I hasten to add that on my (shed of a...) M3, I just replaced the pipes, as it was they that were knackered and I didn't see benefit in replacing a perfectly good radiator. I'm a lot more caring of the Zettie and it would get the lot if required :-)
Best regards,
Sam Lever.
My Financial Blog
Jet
Post by Jet » Wed 08 Jan, 2020 22:27
Cheers TJ/Sam,
Will have to find time to get a closer look
