Undertray fixings
TJS
  Z1 roadster
Undertray fixings
Post by TJS »
I can't track down a part number for the coarse threaded brass chassis inserts for the rear undertray torx fixings (item 12 in the link). The usual problem; the insets unscrew and wear rather than the torx stud. Do I need to track down similar size generic M6 rivnuts ? If so recommendations welcome !
https://www.realoem.com/bmw/enUS/showpa ... Id=51_1857
Alternatively not sure if the "M8 blind rivet nut flat headed" part no 41132291403 and hex bolt with washer (07119915082) used to attach the floor to the chassis will work. (Items 5 & 12)
https://www.realoem.com/bmw/enUS/showpa ... Id=41_0333
a1z1
  Z1 roadster
Re: Undertray fixings
Post by a1z1 »
Hi Tj,
You are close.. the part is listed on the diagram number 11.
There are 2 sizes
41122292143 uses 4 on the car and is used to hold the handbrake onto the floor.
41622290686 Receives the bolts that hold the undertrays and sill panels on.
Regards,
Ivor
________________
TJS
  Z1 roadster
Post by TJS »
Many thanks Ivor,
A set of the correct sized "threaded plugs" have been ordered from BMW Germany @ £7.50. The respective Torx screws are no longer available from BMW but generic stainless studs and washers are widely available.
TJS
