Rear Shock mount removal issue
F.Brossaud
  Z1 roadster
Post by F.Brossaud »
This week end, I decided to change shock absorbers.
I am facing issue with rear ones, which are the easiest
Impossible to remove the Rear Shock mount / Rear Suspension Top Strut Mounting :evil: ..
It seems hole in the frame is smaller than the metal/rubber part on the piece, so impossible to slide it down once 2 bolts are removed.
Did you ever had such issue ?
Thanks for your help.. I am getting nut
Frédéric
F.Brossaud
  Z1 roadster
Re: Rear Shock mount removal issue
Solved :D
You just have to press / pull hard... it is just stuck due to the carpet
