for a cheap maintenance, try vaseline, it helps keep door seals soft.
I have also used a product called Gleitlach ( i think that's how it's spelt!)
it comes in a bottle with a felt tipped applicator.
hope this helps!
hope this helps!
Thanks for the link above must get some of the Gummi stuff
I've been using Autoglyms Vinyl and rubber care although I do use it weekly during the summer so rubbers tend not to dry out. As said Vaseline contains Petroleum Distilate and will damage the rubbers eventually
pedro20001 wrote:for a cheap maintenance, try vaseline, it helps keep door seals soft.
hope this helps!
I heard that you shouldn't use vaseline as it contains pertoleum which can corrode rubber. I've used gummi-plefge on my seals and it makes them like new!
