Hi I have a problem with my z3 it's the 6 cly 2 ltr 1999, Starts up fine, drives well, but after returning to idle, it drops a cylinder, turn it off for 5 mins and all is ok, I have changed the plugs, I took the coil pack leads out one by one listening for the engine note to change, which it did until I got to the cylinder nearest the dash, no change seems as if there is no spark, I changed the coil packs around assuming it was one of those, but did the same thing on same cylinder. It has been on a machine and showed up no faults.
Like I said it runs fine until you sit in traffic for more than a couple of mins.
Be great if anyone has suggestions. Thanks
Cylinder problems
Re: Cylinder problems
Thanks for the ideas, got a computer on it, stating fuel trim error and dropping 2 cylinders, reset the computer by pressing a button in prog, all fine for 20 secs then same errors started up, so took another cover off the top of the engine, one beside plugs and fount a air hose with a great big split in it, needless to say it solved the problem.
This shows what I have been preaching for ages - a computer diagnosis is not as good as intelligent and logical fault-finding. Some owners with idle problems have replaced the idle valve, then the spark plugs, and then the Lamda probes, then the airflow sensor, then the camshaft sensor - and then found that the intake bellows had a hole in it!
Most idle problems are caused by air leaks.
