1. Remove the rest of the handle surround by loosening two screws inside the glovebox. You won't need this again if replacing with a new part.
2. The barrel is actually really easy to remove by loosening 4 clips at the back of the handle.
3. Remove the barrel with the key in as this stops any of the parts of the lock mechanism falling out.
4. There was a new ring with the new handle (my original one wasn't broken but used the new one anyway). In either case remove the old one from the barrel and fit whichever one into the new surround.
5. Push the barrel into the new surround using the key until you hear it click into place.
6. Replace into glove box door using the same two screws. Tada!!
