got a bargain on flea bay for a set of 4 ac type 3 18inch wheel rims - v good condition except for one which is cracked .. not sure if genuine but none too bothered to be honest
anyhow need some advice if possible - plan is to fit these rims and a tyre set to replace my 17in current rims (will fit them with winters) on my 3.0
The AC's were apparently taken off a 5 series and are 18 X 8.5 all round .. et stamp on the back of the rims seems to say 0/7 - which is kinda foxing me as I understand that the (non m) z3 had an et of 35-43 ish
As I say one of the rims is split - there two piece so either a weld or a restore is possible - would also like to get a light refurb on all to bring them pristine .. don't plan anything too radical tyre wise - haven't fully decided but thinking of avon rainsport 3's but in sizes to match UK's speed hump nastiness
so my question is do I sell one of the rears and go for what seems the optimum - a naturally staggered set i.e 18 X 8.5 front and either 18X 9 or 18 X 9.5 at the back
or do I repair and use concentric spacers to best fit - i.e a 20mm concentric kit to space out each of the rears by 10mm and leave the front set as is (hope that they will be flush nut if a small spacer is required then ok) -
the spacer option seems the more logical choice given my budget but I welcome any advice on set up and particularly anyone who has spaced out 5 series type 3's to as while I can measure its hard to visualise the final flushness without all being fitted so any pics of this wheel set ront and back would be a really great help in my decision .. hope this makes sense and any advise welcome
regards to all and bring on the sunshine - my z inspired tan caught in early April is fading
PJ
ac type 3 18 wheels
Re: ac type 3 18 wheels
5 series wheels won't fit and depending which 5 series they where off the bore may wrong as well.
Also I would not fit a cracked wheel that's been welded
You really should research the offsets and bores before buying wheels and not just assume they will fit, not so much of a bargain when they don't
Agree with Johntt.
5 series wheels have a smaller offset so will stick out more than zed or 3 series wheels so spacers will make it worse.
here's a link to BMW wheels.
http://felgenkatalog.auto-treff.com/
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
brought 4, 3 of which are in great condition - Rondal make for £59 quid so a no brainer, yep et means the fronts unlikely to work unless I use 215 35 tyres, rears will be fine I believe, will flog the fronts or possibly get the faces of the two piece set on a new wheel rears to make them 18 X 7 1/2 J - but need to load them on and then make a decision
thanks for the wisdom as ever
regards
PJ
regards
PJ
Not sure the rears will fit unless you have a Z3m. 5 series are usually the wrong offset for a none ///M z3 all round. General rule of thumb is ....
None ///M Z3 = 3 series offsets all round
///M Z3 = 3 series offset front, 5 series offset rear.
Spacers can then fine tune.
Ps ac schnitzer made the type II race in specific Z3m fitment so no need for spacers but they are very rare
Thanks again .. tend to avoid thumb rules wherever possible myself.. as I say I'll try them on with a variety of tyre combinations and reach a view taking into account tyre possibilities, likely handling impact and looks .. in no rush as have a tidy set of staggered BBS 723/724's on currently.
regards
PJ
regards
PJ
Mmmmmm I find having a basic idea rule of thumb saves wasted money in the long run but good luck getting them to fit without a slam dunk camber & stretch look ( unless that floats your boat)
