Thinking of going down the power flow exhaust road, you good folks that have had them fitted have you seen any improvement in power or mpg, asking because the fitter at mr tyre says unless I go silly on noise levels there will be little or no gain over the BMW set up, getting to old for boy racer noise levels.
Thanks for the feedback
Power Flow Exhausts
Re: Power Flow Exhausts
I’ve not had Powerflow but did have Pro-Speed rear boxes.
I can’t say I noticed any difference in performance but easily noticed the drone at 30mph.
On any modern car, it's the cat converters which create the greatest restriction to getting the exhaust gasses out. So, if you want to achieve a small power gain, you have to dump those. Whether your laws allow this or not will determine your decision. In any event, the gains aren't so significant that you would notice much. You will notice a fuel consumption improvement if you made a careful study of a before and after removal.
Oddly, it's the emissions controls on cars which have robbed much of the power, but at the expense of higher fuel consumption. If you really want improved performance, the only practical way is to replace piston rings, and do a head job - valves, valve seals etc.
The cylinder head is by far and away the most critical area of power since that's where the greatest pressures are created. Ant "leaks" past both intake and exhaust valves will result in poor combustion and loss of power. Piston rings are the only other component which relates to effective combustion / power, since they provide the "seal" on the actual strokes.
Doing the job isn't as difficult as it may seem at first and with a decent manual like a Bentleys, it can be comfortably achieved. The only obstacle is cost. In the process of doing a head job, there are a variety of tools required, and parts which need replacement whether you like or not. Obviously, time and space to carry out the task is a prerequisite too. However, once done, you will be grinning from ear to ear with the huge power gain. Your motor is essentially new again, with all the original horses hauling ass...
I have rebuilt a few BMW motors and have done them in the most economical way I could each time, and the results have been a success every time.
Id powrlow exhaust for 12 years. very good but make sure you get the quietest available or you'll go mad wiith it
has anyone replaced the cats with 300CEL cats or something? (more like racing cats)?
