I have in the past seen posts regarding the fitting of the face lift seat adjustment switch to the older pre-face lift wiring loom. I've had a search, but nothing has come up in that regard.
Perhaps someone can help with locating the posts regarding the way to complete the connection issues.
Thanks...
Re: seat adjustment switch
No problem - sorted.
I collected a "broken" old style switch last night and discovered that other than the power supply connection connector, the other 2 connectors were identical. So an easy swap of the old type connector to the new style switch and loom.
