Front foot well speaker upgrade ?? Originals not that bad
Brittas
Post by Brittas »
I have put a pioneer head unit in my 1.9 Z3 which has really improved the music sound. I have tried a 15cm pair of kenwoods that were £55 from Halfords ..... Sounded worse than standard speakers. I have tried some Fusion Encounter 240w . 6.5" 4 ohm. EM-CM65 ... these sounded worse.
It seems the original speakers are not that bad with an upgraded head unit.
I guess I will never get deep bass out of a 15cm speaker. I probably am going to stick with what I have unless anyone knows a speaker that will be a definite upgrade.
Re: Front foot well speaker upgrade ?? Originals not that bad
Post by Gazza »
Did you run new wiring to the speakers?
The old speakers have their own amp.
PeteW Surrey
Post by PeteW Surrey »
Hi Gazza
I have a query in respect to your comment, is this an amplifier behind the left hand foot-well speaker or cross-over electronics for frequency split between the main and the tweeters?
Peter
Brittas
Post by Brittas »
I used existing wiring. Are you sure the bog standard set up has an amp?
Post by Gazza »
PeteW Surrey wrote: Sun 07 Apr, 2019 10:38 Hi Gazza
Peter
Indeed, amp behind the LH footwell speaker.
Post by Gazza »
Brittas wrote: Sun 07 Apr, 2019 11:49 I used existing wiring. Are you sure the bog standard set up has an amp?
I upgraded my headunit and speakers, used new wiring to all speakers (7) inc sub
Dennisthemenace
Post by Dennisthemenace »
I’m using an Alpine KTP 445 amp with my Alpine HU, it’s ok but as said you won’t get any real bass as they aren’t in sealed enclosures, I’m looking out for the sub enclosure and accompanying parts, then I will run my old 5 channel Genesis amp to power the lot!
882-user-1
Post by 882-user-1 »
Gazza wrote: Sat 06 Apr, 2019 18:21 Did you run new wiring to the speakers?
Just found this!!! :(
Just replaced rear speakers, drivers side with new kick panel speaker and new door tweeter, then tweeter in passenger door. And took passenger kick panel off to find .... this!!!
How do bypass it???
I have a new head unit which is i think will be fine as amp too for now.
Does this thingy-amp power all speakers or just front?
I'm assuming it had inputs for 12v, gnd, left +/- in, right +/- in & right +/- (amplified out).. no left out as connected to speaker. is the right?
anyone cut this out and wired a bypass? help?!!!
Hi 882-user-1. I'm afraid that Gazza sadly passed away at the beginning of the year, so I'll answer on his behalf.
There is lots of info on here if you search for "footwell amplifier".
Here are some of the more interesting threads that I turned up:
viewtopic.php?f=10&t=39250&p=364849
viewtopic.php?f=10&t=9881
viewtopic.php?t=10889
There is a pinout in the first one, but the suggestion of running fresh wiring may be the cleanest solution, as you'll be able to use thicker wire to drive the speakers directly.
