Rattling door window
LaRy
Post by LaRy »
If anyone has the same annoying problem as I with a rattling window when the top is down and window is in upper position, I have a solution. I know what can cause it. Short, it is a plastic guide attached to the lower rear end of the window. Solution, if anyone else have this problem, come back, and I will write a description.
