New Rear Window or Entire Roof
njathind
Post by njathind » Mon 06 Jan, 2020 19:30
Need some advice.
Finally traced the leak into the boot, turns out it was running in through the rear window zip in the bottom left corner.
Filling up the well the roof folds into and dripping down into the boot.
Managed to work out that if I carefully fold the edges of the roof back under the black plastic bit if the rear window, it stems the leak but doesn't stop it, sadly the bit around the bottom left corner doesnt quite reach under the black plastic trim.
Apart from this issue with the rear window. The roof is in pretty good shape.
Question is, will changing the rear window fix this? Leaving the roof fabric tucked under the black plastic window trim perfectly?
Or is it sadly a case of new roof also?
Hoping it's just a case of the window seal trim shrinking slightly and a window is all thats needed.
Many thanks in advance.
Re: New Rear Window or Entire Roof
Post by colb » Wed 08 Jan, 2020 10:07
You could try some glue under the material that tucks under the beading around the window to get it to seal. Very much a fiddle of a job to do but worth a try. A new zip in window isn't going to curethe problem with the material needing to be tucked under that beading. Alternative is a new sewn in window but that involves taking the hood off and a trimmer sewing the new window in. You could get a complete new hood with sewn in window put on the car by one of the UK trimmers who do this for circa £300 when I last looked. A lot of members use Jack Smith at Swansea who can do the job with a choice of hood colours and completes the job in a day whilst you have a look around the town. There are other trimmers, one in Croydon, often mentioned in threads on here. For what you are going to pay to have a window sewn in it might well be worth replacing the hood completly.
2003 BMW 2.5 Z4
Tufarlian
Post by Tufarlian » Thu 09 Jan, 2020 09:03
Black silicone is better than glue.
It can hold the fabric in place over the zip, prevent water getting through the zip and if you decide to replace the window after all it pulls away easier.
Mark
Bertie
Post by Bertie » Sat 11 Jan, 2020 20:49
Have you tried "Captain Tolley's Creeping Crack Cure " [It's real product not a joke ].A styrene based liquid which penetrates cracks and polymerises to form a water tight seal . I've used it to seal windscreens and boot seals on old cars , my son has used it to seal windows on his sail boat cabin . It works every time. .
Bertie
Bertie
Post by Bertie » Sat 11 Jan, 2020 20:50
Bertie
Post by Del » Sun 12 Jan, 2020 20:48
It's only glued from the factory. I've used Bostik Soft Plastic Clear Adhesive successfully in the past and others have used "Stormsure". Apply glue and used a credit card to get the canvas to tuck under the plastic strip. Do not be tempted to use typical super glue as it dries hard/crusty, makes a mess and is not waterproof.
wonderloaf
Post by wonderloaf » Tue 14 Jan, 2020 10:10
Bertie
This is really good stuff, just used it to seal the windscreen on Volvo, probably saved me many 100's of £££££££. Worth having 'just in case'!
2001 Titan Silver 2.2 Sport
PeteW Surrey
Post by PeteW Surrey » Sun 19 Jan, 2020 12:48
I have a similar issue with my Z3, water condensing on the u/s of the boot lid, misty windows and an 18 year old tired hood with poor rear window seams. So, I took the car to Soft-Tops in Croydon to see Dee and had the entire roof replaced including the rear window for £495, takes about 3 hours, thanks Dee for the nice job you made of it. Thanks also to my wife for treating me to the hood for my birthday!
