output shaft
eclips
output shaft
Post by eclips »
BMW Z3 2.8 i must have changed output shaft , but i can not get the big nut 29mm loose ( sits in the hub )
it is very stuck ,, good idea wished , best regard Allan
Althulas
Re: output shaft
Post by Althulas »
Hi Alan a good impact gun will make short work of it, it’s how I did mine Makita DTW1002Z 18 V LXT Brushless 1/2In Impact Wrench Bare Unit, 500 W, Blue, Large https://www.amazon.co.uk/dp/B01AVXACYO/ ... EEbPMTPJQ5
A bit of an outlay with an added charger and batteries but an invaluable tool. Dewalt have a similar spect one DEWALT 18 V XR Brushless 1/2 Inch High Torque Impact Wrench (950 Nm), Bare Unit https://www.amazon.co.uk/dp/B00VXN7TUW/ ... EEb3JCEM0F but have the added bonus of the batteries being able to be used in a cordless angle grinder as well . If your lucky to have your car on your drive/ garage you could buy a corded one cheaper but make sure the specs have a high nut busting torque.
Juvvajuvva
Re: output shaft
Post by Juvvajuvva »
The only ones I have are 36mm.
Put the hand brake on, take the wheel off, get a long bar and put it between two of the studs and lock it out on the floor or built up wood choks. Get your breaker bar with your 36mm socket, slide a scaffold pole over the breaker bar handle and undo the nut.
Then take the calliper off.
You can do it without the calliper or disc on the car no problem but the car needs to be on very sturdy jack stands , not little cheapo ones.
It’s safer in your own with one wheel in the ground with the hand brake on.
eclips
Re: output shaft
Post by eclips »
thank you so much for good idea,,,
eclips
Re: output shaft
Post by eclips »
thanks for the good advice , then the nut came off ,,, i need new drive shaft ,
is there a suggestion for unoriginal type , or anyone who can suggest a product
to my Z3 2.8 1998,
Althulas
Re: output shaft
Post by Althulas »
Why do you need a new shaft can it be refurbished. There are secondhand ones on eBay but twice the price of a new but not oem from BMW https://www.ebay.co.uk/itm/142313097525
eclips
Re: output shaft
Post by eclips »
hallo ,, how much do i tighten the shaft nut Nm in the wheel hub , ???
i have bought 2 new ones , drive shaft , with regards Allan
Althulas
Re: output shaft
Post by Althulas »
There’s a Zip file in this thread https://zroadster.org/threads/z3-torque-info.32785/ with a list of torque values for Z3 and Z3M
eclips
Re: output shaft
Post by eclips »
Hej , many thanks for your help , nice with the whole list , regards Allan
