Third Brake Light Plug
Thanks to the hamfisted efforts of a previous owner, I need to replace the entire third brake light which shouldn't be too difficult. He also cut off the plug which attaches to the unit, which I would like to replace. There are two wires going to the light, but from what I can make out on diagrams, it's a three-pin socket. Does anyone know the part number of the required plug, preferably with wires attached? TIA!
Re: Third Brake Light Plug
Go to www.realoem.com click Classic model and enter your car details.
You can then search parts by category and get a part number.
Z3 S54 M roadster
, BMW Z1, BMW M3 CSL, Z4M Coupe
Z3 S54 M roadster
I tried that, but it doesn't show a part number for the actual plug, as far as I can see. The closest I can find is a repair wiring loom for the boot/trunk, but no specific numbers for individual connectors. It would be an expensive fix as the wiring is ok, apart from the missing plug. Might have to try soldering the wires to the pins on the stop light, but going by past soldering experiences, it probably won't end well!
I've just looked on RealOEM at the 3rd brake light and it shows a diagram of the light without a cable attached, suggesting that a cable plugs into the light. However, when I went onto ebay to look at lights for sale, most are shown with a cable attached and a 3 pole plug at the far end of the cable (see ebay 212572310360). Does your brake light have the cable and plug attached? If so you MAY need (only saying may) 3 pole universal pin terminal uncoded (part number 61136931929 plus the pins). Unfortunately RealOEM doesn't show a photo of the terminal, only a sketch but you might compare the ebay photo of the plug and the sketch and see if you think it's worth a try. If, however, there IS a plug built into the light and you need a socket to fit it, then I'm out of ideas (although why BMW would produce a short cable with a plug at one end and a socket on the other is beyond me) I'm afraid that BMW plugs & sockets are a nightmare as there is usually no indication as to where they are used.
Many thanks for your help, it's a pre-facelift light with a socket, into which the plug I'm after attaches to. I think the facelift version has a lead attached with a plug on the end, judging by the units I've seen on sale on eBay. I think the plug I need is female, the pins are on the light unit, but I think finding the correct one will be tricky!
