Master brake cyclinder
Z3andZ4
Post by Z3andZ4 »
Can anyone help please?
2001 Z3 3 litre roadster needs a replacement or refurbed Master brake cyclinder.
Apparently none available from BMW Germany!
Many thanks indeed, otherwise car going to die 😭
Neil
2006 Z4M coupe - Interlagos and red
2011 530d Touring with 19’s Blue and cream
http://i1167.photobucket.com/albums/q62 ... huiwqu.jpg
LaRy
Re: Master brake cyclinder
Post by LaRy »
The car should not die! You have a couple of alternatives:
You are right, the BMW part 34316754048 seems to be out of stock everywhere. The alternative is to buy some copy, most probalbly made in China.
But I would go for a renovation kit and use some brake shop for a renovation. It is simply made. If it is no rust in the cylinder you can change all the gaskets easy. If it is rust, a professional shop will renovate it definitely in less than an hour.
In the old days, you always made renovations of the cylinder instead of buying a new.
Or find a used one. Search on the part number! It must be used in a lot of cars.
I found one link that seems to have it: https://www.original-autoparts.com/prod ... a560f35e98
Z3andZ4
Post by Z3andZ4 »
Thank you very much for responding so comprehensively.
I will get onto this immediately and let you know how it goes.
Really appreciate the support.
Neil
TJS
  Z1 roadster
Post by TJS »
If you are unable to source a replacement it may be worth giving Past Parts a call. They can rebuild your existing unit with a new stainless steel sleeve and seals.
https://www.pastparts.co.uk/services-products/
Z3andZ4
Post by Z3andZ4 »
Thank you so much for replying.
I think I might have one from eBay, but we know what delights buying from there sometimes brings.
I shall treasure this contact and ensure when the eBay one goes in I retain the one it is replacing, which would potentially give me two bites of the cherry with past parts.
The one available in Germany apparently never replied and one I found in 🇺🇸 won’t ship to UK!,
Thank you.
Neil
Z3andZ4
Post by Z3andZ4 »
Thank you.
Neil
LaRy
Post by LaRy »
Seems like BMW has the brake cylinder in France; https://www.online-pieces.fr/bmw-pieces ... inder.html
Z3andZ4
Post by Z3andZ4 »
Thank you for all your advice.
My eBay purchase has been installed and everything is hunky dory.
I really appreciate the time and effort you took.
Neil
LaRy
Post by LaRy »
Nice to hear that it is working and the car will survive. Also nice that you are giving feedback!
BR/
