Wheel fitting help needed
the_youth
Post by the_youth » Thu 21 Mar, 2019 00:32
Currently looking at a set of wheels for my M. Specs are:
Front: 8jx18 5x120 et40
Rear: 10jx18 5x120 et13
Will these fit?
Re: Wheel fitting help needed
Post by Gazza » Thu 28 Mar, 2019 21:54
The front will ‘poke out’ 8.3mm past the OEM set
The rears will ‘poke out’ 1.3mm past the OEM set
So yes they will fit.
Check the centrebore size, OEM is 72.5
www.willtheyfit.com
