Need set of Lambda sensors for S50
Robin
Post by Robin » Mon 08 Apr, 2019 21:01
I'm having trouble finding a supplier give me the correct part numbers to make a set of four Bosch Lamda sensors
My understanding is I need one for pre cat & one for post cat for cyl 1-3 & same for cyl 4-6
But part numbers given to me by suppliers don't match what's on their site
Do I need four different sensors or two pairs ?
My guess is only difference between a pre Cat sensor for cyl 1-3 versus cyl 4-6 is the lead length.
Same ref the two post cat ones.
Does anyone know a good supplier & the part numbers?
Need to buy Bosch, as I brought some unbranded ones & they packed up after a year !
Thanks in advance
'High G' motoring enthusiast
Re: Need set of Lambda sensors for S50
Post by pingu » Tue 09 Apr, 2019 13:48
S50 only has two pre-cat sensors only. One on the 1-3 pipe and one on the 4-6 pipe. There are no post-cat sensors on the S50, but there are on the S54 (which has a different system up to the rear boxes).
http://www.realoem.com/bmw/enUS/showpar ... Id=18_0229
Parts 26 and 28
The length of the wire isn't that critical (providing it is long enough), so 2x Item 26 won't be a problem if it saves some pennies. but 2x Item 28 will mean that one wire will be too short.
Google the part numbers to find Bosch equivalents.
Robin
Post by Robin » Tue 09 Apr, 2019 14:31
Excellent Pingu. Much appreciated. All makes sense now
