Custom Z3 Focal Subwoofers
dooby
Post by dooby » Sun 18 Jul, 2010 13:06
Well the storey goes I built myself a custom subwoofer for my Z3m last year to replace the frankly terrible Harmon unit.
After this I got quite a few requests on here for more units.
I decided to go with a high quality 6" subwoofer from Focal
(£85.00 retail on its own. If your are not familiar with Focal they are
one of the top hi end speaker manufacturers)
as the box volume would be spot on.
So after a few different designs I have a finished article.
The unit fits snug in the original subwoofer location. All that is
required is the removal of the original unit and brackets.
I would also recommend dynamatt for the surrounding areas due
to the increased output.
I have tested this unit on a Genesis Mini Block and it absolutely sings.
Tight fast and punchy with great output for its size.
I would rate this unit around 150w rms 4ohm.
NB
The standard harmon amp will not run this unit to a satisfactory level.
The price is £150.00 collected from Essex or I can post in the UK for £10.00. I will make to order which due to work will take 3-4 weeks depending on demand.
The sub will transform the sound system in your zed and will outperform the roadster sounds units costing 4 times as much !!
Thanks Glen
http://i985.photobucket.com/albums/ae33 ... C01543.jpg
Post by shantybeater » Sun 18 Jul, 2010 13:42
Glen,
Great news - the only thing that bothers me is my car doesnt have the standard subwoofer instead it has a cubby hole. Does this fit in the cubby hole as well?
dooby
Post by dooby » Sun 18 Jul, 2010 13:49
It should do as the internal shape should be the same. Post a couple of pics of the area and i will confirm mate.
VikingSven
Post by VikingSven » Sun 18 Jul, 2010 14:13
Very tempting although I think it would rattle the perspex windbreaker I have a bit :/
Suggestion
Post by Brian H » Sun 18 Jul, 2010 14:57
Hi dooby,
Great job, the unit looks really good.
If I could make a suggestion without being cheeky, using a router and round over bit on the top piece would transform the look and more suit the countours of the car, this would also make your unit look more OEM.
I hope you do not take this as critisism and more of a suggestion as you have done a good job :thumb:
Post by shantybeater » Sun 18 Jul, 2010 16:17
^^ that's a very good idea
I'll get some photos of the storage compartment later
dooby
Re: Suggestion
Post by dooby » Sun 18 Jul, 2010 16:36
Ardchyle wrote:Hi dooby,
I did round it slightly, but more of a curve could be added no problem.
Althulas
Post by Althulas » Sun 18 Jul, 2010 16:37
The rounded edges would finish it off to a T. I've got the same setup a s Shanty will these pics be sufficient?
dooby
Post by dooby » Sun 18 Jul, 2010 17:15
Its the same shape by the looks of things so you would just need to remove the box area. With the original sub removed from my car im just left with a bare metal frame inside and it sits snug on the top surround.
Post by shantybeater » Sun 18 Jul, 2010 21:21
Can you give us details on the supplied Focal Sub?
dooby
Post by dooby » Sun 18 Jul, 2010 21:57
I work for a high end hi fi company and sell Focal domestic loudspeakers I run there utopia range in my M.
The woofer I decided to use is a 6wse which performs sub bass duty in the £1800.00 826W Le's
Have a read of this for some more info The W cone drive units.
http://www.techradar.com/reviews/audio- ... 639/review
Hope this is of help
Post by shantybeater » Fri 23 Jul, 2010 18:47
Ah I see, i cant seem to find any info on a 6WSE on the focal website though? Sorry for all the questions i'm just trying to find everything i can about it before i order
dooby
Post by dooby » Wed 28 Jul, 2010 15:05
Its a new custom made drive unit for that specific speaker.
I spoke to the Focal rep who i know very well and asked him to recommend
a driver for the job in hand. Basically its one down from the Utopia range in there driver line up.
If you scroll down this link there is the specs for the standard 6w.
The unit I am using is the new improved version with more excursion and higher power output. It will drop down to around 35htz -3db which is great for a 6" drive unit
http://www.avsforum.com/avs-vb/showthre ... 1&page=120
Subwoofer
Post by shantybeater » Thu 29 Jul, 2010 08:18
PM'd
dooby
Post by dooby » Thu 29 Jul, 2010 13:25
All Pm's replyed :-)
Post by Gazza » Fri 30 Jul, 2010 10:35
You're going to be a busy man :)
S54 M roadster Image, BMW Z1, BMW M3 CSL, Z4M Coupe
Post by swamper » Fri 30 Jul, 2010 17:47
are you going to keep the line running.......as i may well be interested in one in the future?
dooby
Post by dooby » Sat 31 Jul, 2010 11:52
garythefish wrote:You're going to be a busy man :)
Your not wrong mate. Had quite alot of interest.
dooby
Post by dooby » Sat 31 Jul, 2010 11:53
swamper wrote:are you going to keep the line running.......as i may well be interested in one in the future?
Hi, yes it will always be possilbe to make you one in the future.
dooby
Post by dooby » Tue 17 Aug, 2010 16:06
Post by shantybeater » Tue 17 Aug, 2010 16:14
Absolutely spot on :thumb: I'll take one....Pm'd
Post by Gazza » Tue 17 Aug, 2010 16:49
Piccies
Being fitted Thursday :D :D
Post by Brian H » Tue 17 Aug, 2010 18:15
They look Superb :thumb:
dooby
Post by dooby » Wed 18 Aug, 2010 12:57
Ardchyle wrote:They look Superb :thumb:
Thankyou, Im going to be building a batch of 6 over the next few
weeks while the saw is out and then just get the speakers per order.
yalden
Post by yalden » Wed 18 Aug, 2010 13:55
These look so much better with the rounded edges, are they still being wrapped in vinyl or just painted black?
I was interested in buying just the box and using my curent lid/sub build but I'm not considering the whole unit!
Someone get up some fitted pics!
dooby
Post by dooby » Wed 18 Aug, 2010 15:58
Its cover'd in a faux leather type cloth. . You would ruin your
current lid trying to fix it to the bottom of the box as you would need to
screw/pin them together. Just using pva is not sufficent.
yalden
Post by yalden » Fri 20 Aug, 2010 12:14
Thanks, defo interested... I'd love to see some fitted photos and any comments from buyers on overall performance?? 8-)
dooby
Post by dooby » Fri 20 Aug, 2010 13:15
Im sure Gary will post some pics up/comment.
I Changed his whole system yesterday and it was a
huge improvement in Sound Quality over the original kit.
Its not an out and out boomer. I design'd it to blend in
and disapear with the rest of the system which it does very well.
Post by Gazza » Fri 20 Aug, 2010 13:34
Very pleased with mine, upgraded the fronts using Focal 130 Midrange and Focal Tweeters fitted to the top of the dash pad near the corner screen vents.
I will probably fit an Amp to run the fronts as the Amp in my Headunit isn't man enough to give the best from the Focals although they are a major improvement on the originals.
Vast difference between the superb sound quality on Original CD's against own recorded MP3's, like night and day :shock:
I'll take some pics in the morning to show the Sub in place.
Glen has done a fantastic job on the Subwoofer, professional quality build and I wouldn't hesitate in recommending his work, First Class :D
yalden
Post by yalden » Fri 20 Aug, 2010 14:35
Sounds good - thanks for the feedback Gary!
You didn't have this fitted at Gaydon did you? If so I must've been blind to have missed it!
Do you experience any vibrations from the subwoofer? I was concerned it might rattle all the surrounding trim...!
Thanks, Chris
Post by Gazza » Fri 20 Aug, 2010 15:12
It was fitted yesterday.
No rattles what so ever, the opening had Dynamat stategically placed.
yalden
Post by yalden » Fri 20 Aug, 2010 16:19
Ah ok, so you lined the compartment with dynamat prior to slotting in the unit! Makes sense...
Dooby - will you be at Ultimate BMW next month?
dooby
Post by dooby » Fri 20 Aug, 2010 17:09
Unfortunatly wont be there as work stops play :-(
dooby
Post by dooby » Fri 10 Sep, 2010 17:44
ShantyBeaters custom sub with a jl 6w3 ..
Nearly finished just got to solder it up, fit the unit and test.
http://i985.photobucket.com/albums/ae33 ... C01590.jpg
Post by Gazza » Fri 10 Sep, 2010 18:01
Pic of Shantys sub
dooby
Post by dooby » Fri 10 Sep, 2010 18:15
Cheers Gary :lol:
Althulas
Post by Althulas » Fri 10 Sep, 2010 18:34
That looks a first rate job. Looks like your going to be a very busy chap.
Post by shantybeater » Fri 10 Sep, 2010 20:45
Glen, looks fantastic!!! :)
dooby
Post by dooby » Fri 10 Sep, 2010 23:13
Glad you like 8-)
tcrichton
Post by tcrichton » Mon 13 Sep, 2010 16:52
Very nice,
Think I'll be looking for one of these soon. Anyone got any pics of it installed?
Tris.
Post by shantybeater » Mon 13 Sep, 2010 20:04
I'll get you some next week! and welcome by the way 8-)
tcrichton
Post by tcrichton » Tue 14 Sep, 2010 09:12
Won't be long until I can see (and hear) it in the flesh I guess!
Post by shantybeater » Sun 26 Sep, 2010 15:51
An update from me: I finally got the Sub installed along with the rest of my install. The sound is brilliant!
I dynamatted the compartment and I get no rattling even with the sub turned up to a high level.
It also really looks the part!:
I cant recommend Glen (Dooby) enough, he was extremely helpful throughout and the level of workmanship which went into making my enclosure is really fantastic.
For more pics check out my progress thread:
http://www.zroadster.net/forum/viewtopi ... 423#257423
tcrichton
Post by tcrichton » Sun 26 Sep, 2010 21:14
Dam that looks good!
Better start saving the pennies so I can get one :-)
dooby
Post by dooby » Tue 28 Sep, 2010 17:41
Im building another one at the moment.
johnjo
Post by johnjo » Wed 29 Sep, 2010 08:07
PM sent
dooby
Post by dooby » Sat 02 Oct, 2010 12:05
All Pm's replyed . . .
siwilson
Post by siwilson » Tue 15 Feb, 2011 09:29
Did anyone fit one o these to a car with the storage box and not one that came with the original factory fit subwoofer? If so, what did you do? Any photos?
I embarked on my install last night and discovered it may be more trouble that it's worth for me.
Thakns
Si.
JAV11S
Post by JAV11S » Sat 02 Apr, 2011 23:24
SiWilson, I too have the storage box in the centre and am interested, did you buy on in the end? How did it go if you did?
JAV11S
siwilson
Post by siwilson » Sun 03 Apr, 2011 12:13
I bought it, but have shelved the idea for now as it is far from straightforward.
In addition to cutting the storage box insert, you need to remove the lid hinges. to do this you need to remove the roll hoops. then you need to clear some space in the front by removing the locking mechanism for the smaller storage bin.
not sure if i will continue the project or not at this point. Seems a lot of modification for what maybe a small gain over my Alpine all-in-one sub behind the seat. We'll see.....
Users browsing this forum: Parki and 2 guests
