Put the hood down yesterday when leaving the GDSF and the nearside cover hinge snapped, which was rather annoying. Any repair suggestions as replacement parts are no longer available?
Covering column rear left HELLGRAU 1 09/1990 51438134777 ENDED
"Covering column rear left"
- Green Genie
- Sponsor 2018
Re: "Covering column rear left"
Hi Tony
Michael in Germany can supply hinges made from plastic.
https://shop.roadster-fashion.de/en/product-45.html
Thanks Keith
Went back to it yesterday and realised the factory glue holding the hinge in place along with the two metal slots had given up. Bonded back in place and problem solved.
- Green Genie
- Sponsor 2018
Nice cheap fix,well done you.
