Z3 2.8 Roadster alternator
Koolflyer
Post by Koolflyer »
Guys, my alternator bearings have been running noisily for a long time, so now the car is back on SORN now is the time to replace it along with the belt and A/C belt. I've got the old Bosch alternator off, and although difficult to read think it's a 14v 80amp (poss 90amp?) For my car there are 80/90 & 120amp units.
Question: As I'm not an electronics expert does it matter if I replace it with either an 80 or 90amp alternator as it's hard to see from the old one? :rtm:
KF
Mike Fishwick
Re: Z3 2.8 Roadster alternator
Post by Mike Fishwick »
I doubt if you would notice any difference, as the alternator - like most Z3 bits - is a standard type, used on many E36 models.
Are you sure that the noise is due to the alternator bearings? The belt tensioner bearings usually become noisey first.
Koolflyer
Post by Koolflyer »
Thanks Mike for that. My 'indi' thought it probably is the alternator bearing, however after some reading up, I too am wondering whether the belt tensioners are showing their age. Mileage 136k so I have now ordered a new 80amp alternator (which I have now confirmed was on the car, labelled 1997 which ties up), both belts (Alt/water pump belt, and air con belt) plus both associated tensioners now I'm doing the job.
Thanks again
KF
Mike Fishwick
My air con belt tensioner got quite noisey at about 130,000 miles too. Replacement of both tensioners would seem to be a good idea at this kind of mileage.
LaRy
Post by LaRy »
Hi, I've been changing the tensioner and must tell you that the quality today is very poor, even if they are looking the same. I got a couple of tensioners making noise from the bearing of the tensioner arm also making a poor tensioning job. If you buy a BMW origin tensioner, they want you to replace the complete solution to a hydraulic one. Very expensive.
In your case, with my experience, I would only replace the tensioner wheels.
Koolflyer
Post by Koolflyer »
Thanks for the input all, much appreciated. A slight update to the alternator for you. The German motor factors supplier who I have ordered the parts did confirm that some early cars were infact fitted with an 80amp version, but recommended a 90amp, which does tie up with Real OEM for my particular car. Additionally, the helpful chap at Sytner (Leicester) said BMW recommend either an 90 or 120amp now. So a 90amp is hopefully winging its way from Berlin. plus the other bits.
KF
Koolflyer
Post by Koolflyer »
FYI, new 90amp alternator fitted, both drive belts replaced (power steering and air conditioning) plus both associated tensioners replaced after 137k. Awful bearing noise now totally gone! Car now back on the road.....and of course it's raining! :head:
